RCU Forums - View Single Post - Break-in Method
Old 06-19-2007 | 04:37 PM
snowbl!nd's Avatar
snowbl!nd
Default RE: ~*please help~*please help~*
I just did
Here i'll even simplify it a bit for you.
1. "From the very 1st time you start your engine, plop the car on the ground & begin running it in a parking lot in 2-3 minute intervals, tuned only *slightly rich* getting the temps up in the 200F range on a normal day. Every 2-3 minutes, shut the engine down & let it cool completely with the piston at BDC, and then fire it back up; continue this cycle until you've run 15 min or so, and then bump up to 3-4 minute intervals. Vary the RPM and don't be afraid to get the temps in the 200's. What you want is heat cycling of the components without the incredible stress that comes with breaking an engine in when it's overly rich & cold. After cycling the engine in this manner for about 20-25 total minutes, it'll be ready for the track and race tuning. I realize this method goes against the old-school "idle on the box" routine, but you'll be amazed once you've completed this break-in routine, your engine will still have amazing pinch w/out sticking at the top AND your engine's compression will last far longer than it will with the "old school" method."
