RCU Forums - View Single Post - Does Monocote have a "direction"
Old 03-05-2003 | 03:17 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default Does Monocote have a "direction"
Originally posted by JWN
Yes, Monokote shrinks more in the direction of the length of the roll than across. You should always cut the material to maintain the length of the roll with the length of the part. If you ever cover a wing with the roll length orientated with the chord of the wing, you will find the covering dips further between the ribs than it would if applied with the span. I have a model at home that drove this point home very clearly.
On a solid surface, you will have greater sag/wrinkle issues with temperature changes.
John
John, thanks for the greeeeeeaaaat tip ! (you can see the word stretches more in one direction too LOL !). I think it is technically sound to expect anisotropic shrinkage in the film as the carbon backbone of the polymer molecules are oriented in the direction of the extrusion. It's kinda like miniscule springs arranged in one direction .
