RCU Forums - View Single Post - Reshaping balsa elevator & Wing balancing
Old 06-19-2007 | 09:43 PM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
Default RE: Reshaping balsa elevator & Wing balancing
You can try steaming the elevator and then clamping it flat. You may also be able to remove the warp with iron on covering, if it is a slight warp. As for the wing, adding a smidge of weight to balance it side to side is a good thing. Just make sure the weight is secured and cannot come loose. Good Luck, Dave
