RE: conversion Miss bud
There was absolutely NOTHING hard about this conversion. I used the motor mount from a 1/8 miss bud, cut it down, mounted the SV27 motor & mount to it. Bolted it right in. The shaft & rudder are stock. The servo & receiver are where they were intended. The SV27 ESC is with the rest of the elect. and the batts went up front where the gas tank was. The hardest part was making 2 cuts in the aluminum mount from the 1/8 bud, which took me 15 minutes to size, cut, and install.
The SV27 motor is an 1800kv I replaced it with an ammo 2300kv motor, plus I have replaced the 1800mAh batts with EP4200's
I'll video that run this weekend!
