RCU Forums - View Single Post - Something different you moders will enjoy
Old 06-20-2007 | 10:51 PM
Amuro
Default Something different you moders will enjoy
Hey guys, this was my latest project. My crappy Radio Shack solder stand broke so I decided to build one myself, saving $15 dollars.
1) I took some stock lumber core plywood i had lying around (any wood would due) and cut a rectangular hole with rounded edges. Then I glued another piece to it. Next I drilled a hole for the bolt. Finally, I sanded then applied 5 coats of all-in-one stain and varnish. Done!
2) I made the soldering iron holder out of a coat hanger and attached it to the base.
What do you think? Not bad right? Not only did it save me some money but it is also much classier, sturdier and prettier than a piece of plastic.
ID:	708030   Click image for larger version
ID:	708031   Click image for larger version
