RCU Forums - View Single Post - how insane would adding 2 hobby rockets to a trainer be?
Old 03-05-2003 | 07:22 PM
Unstable
Default how insane would adding 2 hobby rockets to a trainer be?
7) I will not operate models with pyrotechnics (any device that explodes, burns, or propels a projectile of any kind) including, but not limited to, rockets, explosive bombs dropped from models, smoke bombs, all explosive gases (such as hydrogen filled balloons), ground mounted devices launching a projectile. The only exceptions permitted are rockets flown in accordance with the National Model Rocketry Safety Code or those permanently attached (as per JATO use); also those items authorized for Air Show Team use as defined by AST Advisory Committee (document available from AMA HQ). In any case, models using rocket motors as a primary means of propulsion are limited to a maximum weight of 3.3 pounds and a G series motor. Note: A model aircraft is defined as an aircraft with or without engine, not able to carry a human being.
so a fixed system (JATO) is ok by AMA.
fist off. dont put them on the wing tips. WHEN one ignites before the other it will send the plane into a spiral.
mount them on the back of the fuse. start with real small rockets to get the thrust angle right so you dont have it pitch up/down on you.
I do know that someone did this with a ZAGI foam wing with pretty good results... just take your time, dont do a "hack" job and it should work out for you.
oh.. and you can get model rocket engines without the chute charge in them. (estes rocket have a red and blue labels for them)
