RCU Forums - View Single Post - T-rex 450 intermittent shacking
Old 06-21-2007 | 07:42 AM
alienteabagger
Default RE: T-rex 450 intermittent shacking
This sounds like a dynamic balance issue.
CG and balance your main rotor blades first. Any weight you have to add to the lighter blade make sure you add it along that blades cg. Also if you are flying the stock length blades, make sure you are flying with a headspeed of at least 2000rpm and lower your pitch to 40%-50% at midstick.
