RE: PCM, PPM? heh?
These refer to the methods of "modulating" or "encoding" the information on the RF carrier from your tranmitter. PCM is a little better BUT the good news is that your PCM transmitter can be set to transmit on the cheaper PPM system and you can buy the less expensive PPM recievers if you wish. Just read you manual and it tells you how to make the change.
