RCU Forums - View Single Post - Prop balancing
Old 06-21-2007 | 09:49 AM
brianengy
Default RE: Prop balancing
Ok, I bought the Top Flite Power Point Balancer last night at the LHS and three props. All the props were Master airscrew brand G/F Series. One was a 10x6, 10x7 and I had one that wouldn't balance, it was the 11x6 prop.
This is what it was doing. This is from the manual.
If the prop comes to rest in a
level position, but is still obviously out of
balance (hole slightly off-center), you
may need to add weight to the lighter
side of the hub (see method 2).
I had a glob of ca glue on the light side but it would not balance out. Did I just get one lemon of a prop? The other ones balanced perfectly.
