RCU Forums - View Single Post - axe cp thread
Old 06-21-2007 | 03:14 PM
  #1183
Rotor13B
Default RE: axe cp thread
ORIGINAL: lablover
Thanks a million Ted..I'm off to go shopping
News flash...Got her about 3 inches off the ground and she was drifting left for about 10 feet. I freked so shut her down. This drifing left is gonna kick mu butt
Joe
Try moving the left/right trim to the right a bit, This should help with the drift. Just keep moving it one click at a time until the drift stops. If you find that your trim is almost or all the way to the right, Check the swash to be sure it's level at rest. If that is ok your going to have to dial out some tail power using the bottom pot on the 3-1. What your trying for is to keep your trim tabs close to center, They won't neccessarily be centered perfectly and that fine, You just want to be able to have the trim available when you really need it.
