Nose drops when throttle is cut.
I was flying my electric MM Magpie today. All went well, but when I cut the throttle, the nose drops to about 25 degrees down. I set the CG per the instructions on a Great Planes CG machine. What would cause this? The battery is being used to adjust balance, and even moving the battery back two inches didn't help.
Thanks in advance!
