RCU Forums - View Single Post - MBX5R Diff Install
Old 06-21-2007 | 10:31 PM
mbx5r4life
Default MBX5R Diff Install
Dang it, one instruction book tells me to use the small o-rings in the front and center diffs, while the supplemental instruction manual says to look at the spec sheet. The spec sheets (I think) tells me not to use the o-rings and different weights for the diffs. Which one is correct?
