RE: prop's what does what?
Pitch is the amount the prop will travel foreward in inches in one revolution. So the higher the pitch, the higher the top speed IF the engine can pull it.
Larger diameter propellers pull more air volume which equals more thrust.
The best prop is usually a compromise between thrust and pitch.
