RE: MBX5R Diff Install
only use the o rings on the out drives that seal the diff, not on the internal gears. and upgrade to the carolinas O rings, the stock ones leak.
common diff oil use is 5000 7000 2000 or 5000 7000 1000 front to rear, depends on your style & track conditions. 5, 7, 2 is most common, i'd start there.
