RCU Forums - View Single Post - Nose drops when throttle is cut.
Old 06-22-2007 | 11:19 AM
broke_n_bummin's Avatar
broke_n_bummin
Default RE: Nose drops when throttle is cut.
... But adding downthrust is only going to help when the propeller is turning. He said that when he cuts the throttle, it pitches down. Sounds like a stall ... like you're going too slow. The extreme dihedral wing will keep the plane straight, but it sounds like the plane is falling out of the sky. After it dives a bit, does it straighten out for a minute then dive again (porpoising) ?
