H9 Cap232/Moki 1.8 question
You better side-mount the Moki, or you will be most unhappy. It will not start inverted. You also need to have a smooth transition from high to low throttle. If it has any hesitation before going to idle, the trim is set too high. That will make it difficult to land, as it will now slow down quick enough.
You will also have to fly it in for landing and I would not recommend any violent maneuvers.
NEWKIII
