NewkIII,
Respectfully,thats all not true.I have this plane with an inverted Moki.Yes you either have to use an electric starter or invert the airplane to PRIME it.It starts fine and runs fine inverted.Mine idles like a watch without glow heat.I use a sullivan dynatron with 24 volts,starts it no problem.The airplane balanced perfectly with no added weight,and the servos in the stock spot.All transitions are flawless,the plane hovers 1/2 throttle,and will power out vertically easily.It also slows to a slow jog to land!!
I live near Allentown,and will gladly demonstrate all of this to you.Also,the invertad installation is very clean and good-looking.
Regards,
Erik
