Wing halves epoxied together with two plywood spars inside and landing gear mounted. Need to final fill and sand with 220 and dry fit the ailerons and hinges. I decided to just use Monokote for a finish as it'll be faster and I want to complete this bird in time for the SPA event here in Asheville next month. Need to pick up some more hinges and also a 2 3/4" spinner from the LHS as it seems the biggest one I have is 2 1/2" and it's too small. Also, some balsa stock for the fairings and look for a router blade
