RCU Forums - View Single Post - Hitec Eclipse 7 QPCM
Old 06-22-2007 | 03:50 PM
A.T.
Default RE: Hitec Eclipse 7 QPCM
ORIGINAL: winger1955 Can I use normal FM receivers with the Eclipse 7 QPCM or do I have to use a PCM receiver? Thanks
Yes, Eclipse can be programmed to operate with all known PPM/FM receivers on same frequency.
Your Eclipse may have all models in memory pre-set to operate as QPCM. Refer to Eclipse 7 Addendum for instructions on how to reset TX. Memory for each model using a PPM/FM receiver must be reprogrammed individually and each time you turn TX on, RF will automatically be QPCM or PPM as input and saved.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links[/
