ORIGINAL: shadow flyer
alright i got er fixed, the way did it, was i took the pullys off and added some washers to lower ut, that way its in alinment. this is an after photo
LOL....mine looked just as frayed as yours. The only thing I had against using a washer is friction against the frame or bushing. You might be inviting problems, that's why I re-drilled the main shaft. I used the locking collar on top to adjust the height of the pulley. See if it'll work I guess. Looks like we got one out of the same batch. I haven't had one problem since I made the mod and everything stays in line. It would also explain the low runtime and the heat on the battery and esc.
