RE: Lanier Mariner 40 MKII ARF 62"
If the hull isn't cracked then most of the water is probably coming in through the joint at the front of the wing/back of the windshield. It is hard to seal that particular area, but packaging tape over the joint seems to do a pretty good job. Just be sure the area is dry before you apply the tape.
