I did a search and found through tower hobbies that the throws should be 1" R/L on rudder, 1/2" U/D on elevator, and 5/8" on ailerons. (more on this at the bottom)
I did searches here, and found this thread:
http://www.rcuniverse.com/forum/m_10...tm.htm#1054764
It says the same except ailerons call for 5/8" up and 1/2" down. My fourstar has one servo operating both ailerons. How can you set this? If i set it down less on one side, it'll be less on the upside for the other direction.
Not to mention, doesn't 5/8" on ailerons vs. 1/2" on elevator seem a bit odd?
Tower hobbies has this:
http://www2.towerhobbies.com/cgi-bin...&I=LXFKA9&P=ML
Center of Gravity: 2-15/16" (74mm) Back from the wing's leading edge
Control Throws-
Elevator: Up & Down 1/2" (13mm)
Rudder: Right to Left 1" (25mm)
Ailerons: Up & Down 5/8" (11mm)
If you notice, 1/2" - 13mm is pretty much accurate.
then 5/8" - 11mm.......thats not right.
I wonder is it supposed to be 11mm, or 5/8" ?????
Just seems like a lot of ailerons compared to elevator to me. I've never had the manual for this four star, I bought it used a while back. Any help/input is appreciated.
