Magic owners thread
To clean up the outside loops you will neeed a symetrical wing . Yada yada bla bla blaaa... The Weston Cougar is roughly the same thing, with the symetrical wing and is a better plane. if you get one and want to use a bigger engine, consider moving the fire wall back
My magic is outfitted with standard servos except HS 81 on throttle (with no problems in almost 100 flights) and i used a 720 MAH 6 volt pack. makes those standard servos come to life. engine is an old beat up GMS 47. I keep switching back and forth from the Macs muffler, and a mouse can pipe.
It has been a fun plane, but i like to try new things so i am stripping the gear off and selling it. Going to try the CG extreem 330.
