RCU Forums - View Single Post - Kit built 4*40 control throws questions.
Old 06-23-2007 | 04:51 PM
rainedave's Avatar
rainedave
Default RE: Kit built 4*40 control throws questions.
Carrell, I could be wrong, but I'm pretty sure your drawing is for high wing models with the servo mounted upside-down under the wing. For a low-wing model like the 4*40 the pushrods should connect behind the centerline of the servo output shaft. That is assuming you want more up travel and less down travel.
David
