RCU Forums - View Single Post - STRYKER F-27C Help
Old 06-23-2007 | 09:03 PM
darren94
Default STRYKER F-27C Help
After a bad crash with my f27c, i did a rebuild and everything looked good to go. Today i was flying it and the motor completely fell apart due to a bent motor shaft. After a closer look, i noticed that the screws holding the motor in the mount were still intact with the prop still hooked to the prop adapter. But, the motor case itself came loose where the back plate mounts to the engine mount and fell off. I gathered all the parts and it looks like the back plate on the motor(prop end) was held into the motor case with glue and it had come loose. So, i am planning on using red lock tite to put it back together. But, my question is this. Will the motor hold up with a barley bent shaft and being held together with lock tite? or should i just buy another motor?
that being said, what brushless motor would be best for me? stock? i dont want to change my battery's, ESC or anything like that but one with higher top end would be nice. I am new to electrics so any input would be great!
