RE: Lanier Mariner 40 MKII ARF 62"
Thought I mentioned the rear end. Check where the side covering overlaps the bottom covering and the fin on the bottom. And consider this --- on an ordinary covering job we always cover the bottom first then overlap the side covering over the bottom. This makes the job look good. But on a hull like the Mariner or a float, I do it the other way covering the side first, then overalapping the bottom covering over that. Yes, it leaves a small seam running along the side but it's much more resistant to peeling loose from the force of the water.
