RCU Forums - View Single Post - axe cp thread
Old 06-24-2007 | 03:14 PM
  #1223
Rotor13B
Default RE: axe cp thread
Put all your links back to stock and set your throttle trim to half. Also, if your throttle lever is sticky this will cause dificulty in control. If this happens take the back off the controller and loosen up the collective stick. Mine is loose enough thatit will fall back to low throttle if I let go of it which gives me precise control on how high it goes.
