RCU Forums - View Single Post - Nose drops when throttle is cut.
Old 06-24-2007 | 08:13 PM
iron eagel's Avatar
iron eagel
Default RE: Nose drops when throttle is cut.
A change of a few degrees will make a big change in how the airplane will fly. If your cg is right it comes down to things like AOI and thrust angle. Typically the thrust angles in models are a max of about 5 degrees, change this by a only a few and there will be a major change in how it flies.
