RE: CP Pro/DX7 power problem??
Yeah I have my Throttle on "normal" set to 0/35/65/85/95/100. It helps having a steep curve but then smoothing out mid to late stick. If you are worried about headspeed put it to midstick and flip to idle, just to see the difference, if you set it right the half stick should be half throttle. If you want to test, put stunt mode 1 throttle at 100% at all points. That is the max this controller will spin the blades. So at midstick you should be 0 pitch and 100% throttle (with my mod from above). How does what your seeing compare, speedwise?
Make sure you know what you are doing or remove the blades before playing too much or you will end up with a broke heli.
DY
