RE: Idles, but More throttle quits
I have a motor that does that too. So what I do is get it close to good and then try a little bit fatter and see what happens and if that does not work try a little leaner and I mean the turn the screw just a hair and you will find it. If you go rich and it falls on it face then you know that it's not that way so go lean and do it like i said just little turns at a time and you will find the sweet place it likes to run at.
