RCU Forums - View Single Post - 11v vs 14v What's this diff. 4s packs users speak up
Old 06-25-2007 | 06:56 AM
cflight
Default RE: 11v vs 14v What's this diff.
If you run a 4s set up you'll need to reduce the motor kv or swap pinions to accomidate the increase in voltage.
Check out the DarkHorse motor pinion calculator to assist you.
The benefit to 4s is for higher Amp draw from high performance motors, and longer run time.
