ORIGINAL: TopherGreen81
If I could just figure out a way that I can pull on the monocoat with out burning my fingerprints off I think it would be alot more fun. I tried a oven mit but I could not grip it. I think thats the reason that wing tips were so hard cause I would burn my finger and have to let go of the covering and it would wrinkle anyway thanks for incouragement keep the tips coming I need all the help I can get.
Chris
I read a couple build threads that discussed covering...
Try welding gloves. They should give you the grip you need, and provide the heat resistance as well...
