RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 06-25-2007 | 06:57 PM
  #3324
tailspins's Avatar
tailspins
My Feedback: (7)
Default RE: U Can Do 3D
Gjeffers
Thanks for your input. I drilled the 2 screws like you suggested. I fished some 1/4 ply down into the mounting area and replaced the bolts with 1/4-20 bolts. Since I am using a dubro fiberglass mount I am using 4 bolts ( 2 additional right at the Air channel) also with 1/4 inch ply and some triangle. Then I dumped in 30 min epoxy to secure things.
MIXMASTER
I added that ply like you suggested. Thanks
Thanks to the both of you for giving me help with this gear issue! I'll let you know how the first few flights go this Wednesday
tailspins AMA 1121
