RE: two masted Schooner
The books give guidance on the weight that you will need. It will tell you how to calculate discpacemnt, then subtract the weight of model. The remaining figure is the amont of ballst required.
The shape is also covered, at it effects lateral profile, placement, and turning circle.
It is quiet straight forward, but needs a little explaining wihich the books do.
good luck
