RE: replacing one aileron CA hinge
No matter what method you use, only use one application of CA on each side. DO NOT re-apply CA to the hinge after you put the initial several drops on the hinge. Dual application of CA will cause it to unbond and eventually fail. I learned the hard way.
DS.
