Insulating blanket mat'l source
Does anyone have a good source for the ceramic blanket material, similar to what BVM sells?
I need it a bit thicker and with a foil backing to provide temperature protection between the tail pipe and white foam in the fuse. of my large turbine U-2. I am using a cooling shroud on the tailpipe but it's 46" long also.
I will need about 9ft^ of it.
Jack
