RCU Forums - View Single Post - Want to install Flaperons
Old 06-26-2007 | 02:30 PM
hebertjj
Default RE: Want to install Flaperons
Try landing with the ailerons up! This is the "air brake" configuration and gets around the loss of washout and tip stall problem by actually adding washout. It also makes the plane really stick without bouncing when you touch down.
