RE: Engine run problems, please help
From your description of your problems I would say that you have issues with your fuel tank. I would pull the tank out and check to see if you have any air leaks in the tank. Also check that your fuel pickup line inside of the tank is intact and has no holes in it. Lastly, check your fuel line to the carb to make sure it doesn't have any pinholes in it as well.
Hope this helps
Ken
