ORIGINAL: ozrcboy
In the same vein as "there's always time for lubricant" (sorry - feeling like quoting movies today) "there's always time for locktite".
Doubt bleary would make that sort of blunder though - 3 years - old hand at this sort of stuff.
If there is two ways of doing things and one is correct,guess which one I will choose? Thanks Crawf,I thought that the X mount would add a bit of support....and I worked out about the Dremel bit on the blind nuts.....after I had coated it with 5 min epoxy..[&o] Repeat 5 times Bleary....dry fit before glueing...grrr.Fits well, though I think I better epoxy on the other side when it drys,there is a small gap now.[
Was too busy thinking about Loctite and which mounts I hadn't done...
Welcome Rowdy!
Bleary.
