RCU Forums - View Single Post - can't get plane to fly
Old 03-06-2003 | 03:03 AM
tylern
Default about how to fly..
i fly rc planes were are we at on the plane?1 is it a ARF ! if not ok who made it ?if ok is it 5 ' wings.or top wing.
is the radio 4 ch.or more.if not start over and get a 4 ch. radio and a arf plane. if it is ok lets fly ok 1 make sure your plane is not to heavey. if it is it will not go up easy.
put your hands under the wing on both sides of the wind by the body.see if the motor leans down a liffle.if not the tail is to heavey.if it is ok good with fuel in it.be sure the fuel is full.and the batt. is good on radio and rec.be sure all servos are going the right way.up down left right.if you have ailear arms the wings be sure they are right to.so move the radio arms/servos around to see that.the stick on the right is to turn left or right and to go up and down.the stick on te left is the ruter and fuel./gas or power.when turning left the right wing should be up.left down to tunr right the left should be up and righ down.if not click that servo.ok then walk about a 100 feet from the plane have a friend see that all is working good,with the ant.one click out.if it does good at a 100 feet turn the plane on and stand behind it make sure the servo for up is were it will pull up slow.not to fast it will stall.run it full gas tell you are 250 feet up then pull back on gas a little. when you are making a turn. turn to the left or right and pull back easy at the same time.fly around and be sure to take off in the wind and land in the wind too.if you need more help ask any [email protected]
