RCU Forums - View Single Post - need help is their a mounting template for the DA 50 engine,
Old 06-27-2007 | 11:34 AM
Prapan
Default RE: need help is their a mounting template for the DA 50 engine,
Normally what I did was putting all 4 stand-off to the engine and then place the stand-off with engine on the transparency A4 size, using marking color to draw the line of those 4 stand off and make the center line in vertical and horizontal direction. Use transparency as a template on the mounting box of the airplane. Don't forget to have the right thrust so the actual veritcal line must be offset for 5 mm approx.
