as far as the primer goes.. i just took mine our, used a hot glue gun anf sealed the hole. All i do to prime the engine is cover teh exhauset hole till i see the fuel reach the carb. only thin is. If the truck stalls when its been running, the exhaust gets a bit hot( or when running at WOT melts your finger print ) but i like this idea way better then that stupid primer
