RCU Forums - View Single Post - Using servo extensions.. tips needed
Old 06-27-2007 | 08:39 PM
flipstart
Default RE: Using servo extensions.. tips needed
I like to keep the odds in my favor-cut the servo lead and add in appropriate length of wire, make good solder joints, use shrink tubing over each connection and then a larger diameter shrink tubing over the entire splice connection. Your leads will be correct length and no connectors to worry about that are hidden in the wing. Use heavy duty servo wire to minimize voltage drop. Also more cost effective than buying the servo extensions.
