RCU Forums - View Single Post - GST revs but BARELY moves? HELP!
Old 06-27-2007 | 09:57 PM
jarlin
Default RE: GST revs but BARELY moves? HELP!
ORIGINAL: .46NitroAddict
Hey JUCD VPR,
After having quickly checked all the above things, can you see movement in the following places? (Put her on a block of wood or a stand or something simmilar, when engine is running).
1/. When you rev your engine, does the flywheel turn? If not why?
2/. Does the clutch engage, & turn the pinion gears? If not why?
3/. Do your spur gears turn? Firstly, 1st gear? If not why?
I can answer yes to all of these, where do I go from here? I am a noobie so as much step by step as possible would be great.
