RCU Forums - View Single Post - need help with gst
Old 06-27-2007 | 10:47 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: need help with gst
If you guys wanna talk dust in your air filters, try living and bashing in the Sonoran desert!! This dust is so fine you will find in places tat you never would have thought it could get!! On a sunny morning near my window you can see the dust floating in the air and it kinda twinkles in thesun light! Anyway, I was cleaning and changing my filters after every run!!!! Well, I thought I need to get my intake into cleaner air so I moved the air filter forward using a plastic tube and a shock spacer clip mounted to the servo with a home made bracket and voila I only have to clean or change the filter after every 5 or 6 runs, what a difference!!! check it out
BTW Clermont hows that clutch holding up??
ID:	712662   Click image for larger version
ID:	712663   Click image for larger version
ID:	712664   Click image for larger version
