RCU Forums - View Single Post - Voltage vs ma rating for reusing chargers
Old 04-25-2003 | 01:38 PM
Rodney
Default Voltage vs ma rating for reusing chargers
One of the limiting factor on current is the internal impedance of the charger. This is primarily limited by the size of the wire used on the transformer in the charger. If you notice, the wall warts usually get quite warm after a few minutes, this is due to the self heating by the current thru the internal impedance and will increase as you lower the number of cells you are trying to charge.
