RCU Forums - View Single Post - axe cp thread
Old 06-28-2007 | 12:10 AM
  #1255
acadwheel
Default RE: axe cp thread
ORIGINAL: Rotor13B
ORIGINAL: harebearva
By heatshrink, do you mean the heatshrink from the barrel connector on the motor lead?
Yes, The solder connections are some times "cold welded" and don't make a sufficient bond to the connectors which will over time fatique and break. Some people have had this problem from the get go, Others it didn't show up for a month or so.
How about the solder joint on the ESC?
What do you think about the + and - being so close on the ESC?
