ORIGINAL: acadwheel
Harebear it sounds like I'm having the same problem as you.
Does your green light come on when your motor is running or is the whole thing dead?
I think my problem is the wire (batt to ESC) or the solder joint @ the ESC.
My problem seems to be strictly with the main motor. When this happens to me, I still have tail rotor control and as I advance the throttle, the pitch of the blades changes but eeeet nooo speeeens! I unplug the red connector then replug and back to normal.
