RE: 3W Ignition modual
The details on the tach aren't on the 3WModellmotoren website, but it's very simple. There is a push button switch included with the tach, you can select the function that would like to use with the switch. Fly the plane, operate the push button and read the rpm's. The Tach can be temporarily mounted or permanantley mounted using the included screws. Hope this helps.
