RCU Forums - View Single Post - axe cp thread
Old 06-28-2007 | 09:26 PM
  #1266
Phishnvdub
Default RE: axe cp thread
ORIGINAL: harebearva
I've been having an interesting intermitent problem. I recently disconnected the red lead from my motor when I did the heatsink mod, of course this is before I found out I didn't really need to. But anyway, I pushed the connection back together and everything seemed fine. Now about every 3rd flight i'm having a complete motor failure. Since I'm still learning to hover this means that it drops from about 5 feet. After that, I push on the two connections to be sure they are seated properly and they always seem to be, and then it works again. This has happened with both lipo and stock batteries and isn't due to low power in the bat. Any ideas? Bad connector? The connectors are perfeclty clean and seem to be in good shape. What up?
I had a bad connection in the bullet connectors from the motor to ESC when I first got mine, I had to resolder it. I'd check there. Mine if I rember right was the positive motor bullet connector from the ESC. Hope this helps, Shaun
